Irgenwas wird drin sein, weil ...
To prevent battery drain, the heated hand grips are designed to function only with the ignition switch ON. The hand grips produce maximum heat with the engine at cruising rpm.
With the ignition switch OFF, dial the left grip to a number setting. Check that the hand grips are not producing heat. Dial the hand grip to the off position. Turn ignition ON, but do not start the motorcycle. Check that the hand grips are not producing heat.
Start the engine. Check the hand grips at all settings for proper heating.
(Abschnitt "Return to Service")
Zwischen dem, was wir sagen wollen, was wir denken, das wir sagen, dem was wir sagen, was wir hören, was wir hören wollen, und was wir verstehen, bestehen jede Menge Unterschiede.
