1. See Figure 3-4. Remove front brake discs.
a. Remove and discard screws (1 ).
b. Remove front brake discs (2).
2. Remove front tire.
3. Remove and discard sealed wheel bearings(3).
4. Remove wheel bearing spacer (4).
ASSEMBLE
FASTENER TORQUE VALUE
Front brake disc fastener 16-24 ft-lbs 21.7-32.5 N·m
NOTICE
Do not re-use brake disc/rotor screws. Re-using these
screws can result in torque loss and damage to brake
components. (00319c)
1. Install tire.
2. See Figure 3-4. Install inner spacer (4) and new sealed
wheel bearings (3).
3-10
3.5
NOTE
When installing front brake discs, align rivets of both discs.
3. Install brake discs (2) using new screws (1 ). Tighten in a
cross-wise pattern.
Torque: 16-24 ft-lbs (21.7-32.5 N·m) Front brake disc
fastener
1148953
1. Screw, brake disc (10)
2. Brake disc (2)
3. Bearing (2)
4. Inner spacer
5. Wheel
Figure 3-4. Front wheel (typical)
94000742
Memento Mori.....
