Ich habe eine Antwort von PS bekommen.
Meine Frage an PS:
"I'm sorry I have to bother you again. I can't stop thinking about the issue with the suspension travel limiter. I took a closer look at everything again. In one of the pictures, there's a disc made of very firm foam visible on the chrome rod of the shock absorber, and above that, a thin metal washer. This limiter is a closed ring that cannot be removed. In the other picture, there's an additional suspension travel limiter (No. 5021-005) visible. It's made of very hard plastic and can be clipped onto or removed from the rod - it has a lateral opening. I removed it so I could take a closer look. I think in your last message, you were talking about the permanently installed limiter that cannot be removed. If I remove the suspension travel limiter (No. 5021-005), I can compress the shock absorber to 238mm, as listed in your details. Could you please give me some information on this?"
Antwort:
"I was referring to both, by removing it you are allowing more travel which would seem like a good idea… but the reason the limiter is there would be due to clearance again we do not recommend removing it."
Fazit:
Was auch immer er mit "clearance" meint. Möglicherweise der Abstand zum Fender, die Bodenfreiheit,...
Ich werde PS nicht mehr anschreiben, riche dort schon etwas genervte Stimmung, weil wieder mal so ein Ahnungsloser zu viele Fragen stellt.
Weiter:
Falls die Schaumstoffscheibe sich tatsächlich maximal komprimieren lässt, wie BlackStar es geschrieben hat, wären die 54mm Federweg inkl. diesem Federwegsegrenzer ja realistisch.
Wobei das schon wieder eine entscheidende Rolle spielt, wie tief ich den Fender setzen kann.
Mal sehen, vielleicht ergeben sich hier ja noch ein paar Infos...
