Forum » Modelllinien » Sportster (Evolution 883 / 1100 / 1200) » Alle Sportster: Vance & Hines Fuelpak für EFI-Modelle
« erste ... « vorherige 46 47 [48] 49 50 nächste » ... letzte » ·
schupp ist offline schupp · 24 Posts seit 01.05.2017
aus Laudenbach
fährt: Sportster XL1200CX Roadster
24 Posts seit 01.05.2017 aus Laudenbach
Neuer Beitrag 19.07.2018 09:14
Danke
probiere ich heute Abend mal aus.
aus Laudenbach
Neuer Beitrag 20.07.2018 06:45
Habe gestern mal eine Mail an V&H geschrieben, heute morgen bekomme ich die Antwort.
Jetzt verstehe ich nicht mehr:
This Fuelpak has not yet been used to flash your bike. You need to go to 'map lookup' while connected and flash the base map for your exhaust system. Once that's done, run the map for 2-3 tanks of fuel before considering Autotune.
AUTOTUNE INSTRUCTIONS (only use if needed after 1-2 tanks of fuel with Base Map)
**Be advised that while Autotune is active the bike will not perform optimally. The AFR table is not optimized, and the cranking fuel/accel enrichment are turned off. This may translate into poor cold start performance, erratic idle, poor throttle response, and general ride quality issues. These will resolve once you ‘Finish’ the Autotune. Letting the bike fully warmup before riding while Autotune is active will help to slightly diminish some of these symptoms.
1) Go to the Autotune tab in the main menu of the app.
2) a  base map from which to start ( whichever slot your correct map is in, most likely slot 1 if this is a brand new FP3.
3) ‘Quick Setup'
4) It will have you flash the bike to run Autotune, follow the in app instructions (i.e. bike off for 30 seconds, etc.)
5) Once Autotune is active, you'll want to break it down into 3 sessions, approx. 20-30 minutes each.
6) After your first 20-30 minute session, open the app and go into the Autotune section. 'Apply Learned Values' and 'Apply'. This will take the data learned and store it, allowing for more data to be collected.
7) After the second 20-30 minute session do the same thing - ‘Apply Learned Values’ and then ‘Apply'.
cool After the 3rd total session, 'Apply Learned Values’ and then 'Finish'. This will complete the Autotune, taking everything learned from each 'Apply' and will build the map/put it into a new slot.
Tupapupa ist offline Tupapupa · 330 Posts seit 11.04.2015
fährt: Forty Eight (2015), FLSTCI Heritage Softail Classic (2004), FLSTC Heritage (2002)
Neuer Beitrag 20.07.2018 06:55
Was verstehst du nicht? Ist doch alles prima beschrieben.
Anschliessen, updaten und registrieren (heiraten) ist eins, passendste Map downloaden, flashen (macht er autom. auf Platz 2, Original wird gesaved), Autotune 2 Tankfüllungen lang, dabei mehrfach flashen, fertig.
aus Laudenbach
Neuer Beitrag 20.07.2018 06:58
Sorry, hätte ich dazu schreiben müssen.
Die Autotune-Fahrt habe ich schon längst gemacht.
Ich wollte, dass V&H die Autotune-Map sich mal anschaut....
Aymara ist offline Aymara · 1892 Posts seit 27.06.2017
fährt: Low Rider S 117
Neuer Beitrag 20.07.2018 07:42
zum zitierten Beitrag Zitat von schupp
Dann antworte denen doch entsprechend Augenzwinkern  ... und frage nach, wie sie auf diese Aussage kommen : "This Fuelpak has not yet been used to flash your bike."
PS: Haste denn nach Autotune auch geflashed?
Chris
aus Laudenbach
Neuer Beitrag 20.07.2018 07:47
Klar, fahre schon seit Wochen mit der Autotune map.
Neuer Beitrag 20.07.2018 08:06
Ja, wie gesagt ... am besten dem Support antworten und genau erklären, wie Du bislang vorgegangen bist.
Chris
Mondeo ist online Mondeo · 9803 Posts seit 17.06.2015
Neuer Beitrag 20.07.2018 11:31
Was für ein Ziel verfolgst du damit?
aus Laudenbach
Neuer Beitrag 20.07.2018 17:35
Ich wollte V&H mal über meine Autotune Map schauen lassen, ob hier noch etwas verbessert werden kann!
Staude ist offline Staude · 559 Posts seit 29.09.2017
aus U.S.A
fährt: 07er Heritage Military Bobber "Milly", 88er Sporty-Projekt "Daisy"
559 Posts seit 29.09.2017 aus U.S.A
Neuer Beitrag 20.07.2018 18:28
Glaub nicht das sich die hier groß Mühe geben. Genau die gleiche Antwort hab ich vor vier Wochen auch bekommen, wollte zwar nur die Grundmap von denen wissen aber sieht schwer nach Copy & Paste aus..
Grüße Staude
Mein Sporty-Projekt
"Meine Definition von Glück?
Keine Termine und leicht einen Sitzen"
Harald Juhnke
Neuer Beitrag 22.07.2018 16:09
Ich denke da antwortet ein Computer großes Grinsen
govidaris ist offline govidaris · 269 Posts seit 14.11.2014
fährt: Forty Eight
fährt: Forty Eight
Neuer Beitrag 27.07.2018 21:05
Was stelle ich mit Auto compression Release ein. Bei mir ist das auf off
Attachment 290735
Ritchy059 ist offline Ritchy059 · 921 Posts seit 25.08.2012
aus Karlsruhe
921 Posts seit 25.08.2012 aus Karlsruhe
Homepage von Ritchy059
Neuer Beitrag 27.07.2018 21:22
Ich würde sagen - Dekompressionventile on/off
fährt: Forty Eight
fährt: Forty Eight
Neuer Beitrag 27.07.2018 21:28
D. H. Bei meiner 48?  Auf on oder offverwirrt
aus Karlsruhe
Neuer Beitrag 28.07.2018 01:33
Hat Du Dekompressionsventile - vermutlich nicht - dann Off!
103638
24.05.2026 17:21
von Falk
